As a continuation to this thread: Re: bleprofile_notifyAdvPacketTransmissions doesn't work.
I'm using SDK 2.2.1 and "advertisement_packet_transmission" is not called in some of my programs.
Seems like some bugs are still inside "bleprofile_notifyAdvPacketTransmissions"
After this line of code is executed, the behavior of my WICED Sense will become weird for the next few downloads and become so difficult to get paired.
SDK 2.X
I have tried it out only on WICED Sense.
Now, I have decided not to use that library anymore because I got a workaround for my application.
Can you test out your code following the procedures given by mwf_mmfae on a tag3 and see how far you go?
This is Taka,
boont suggest to see the procedures and code from mwf_mmfae, that's my question, and there is no code from mwf_mmfae at all.
At the last of the procedures, arvinds said there is a bug at SDK2.1.1 and he suggest to update to SDK2.2.1. I havn't update my SDK yet.
prayook use SDK2.2.1 and it sounds still the bug is in the SDK.
I think we can not use "additional_advertisement_control.a" because of the bug and it's not fixed yet.
I already gave up to use the function...
I think Broadcom have to make software document.
Have you got a chance to try out your code on the tag3?
So is the "correct answer" that this API is still broken in SDK 2.2.1 and will not be fixed?
If that is the case, is there a sample application that describes how this is done with Wiced Sense?
Just to add FYI...
I also attempted to use this new SDK 2.2.1 feature some time ago and found it gave strange behavior and not the result I expected. Similar to what you described. I was interersted to try it for some reason, but it was not a must-have, so when it didn't seem to work I moved on to other things.
