Writing to BCM20737S
I have a problem about writing to bcm20737s.
I don't know the reason why, but frequently mistake writing to bcm20737s on my original pcb using UART.
Is there any special condition if I want to write always correctly(for example: writing cable must be shorter than 3cm...?)
If you know any document about this problem, please show me...
Below is a comprehensive blog on programming. Read from section 5.
Programming the TAG2/TAG3 Board using command line tools
Does programming always fail?
Please check what happened by download.log, etc.
MichaelF_56
kawamura,
Is this still an issue?
Dear sir.
Sorry for late reply.
This is still an issue.
We wrote amount of bcm20737s (about 2500pcs) and failed about 20pcs.
Then we never write failed bcm20737s even using recovering.
Are there authentic writing sequence?
If it exists, we need to know.
thank you.
boont
Thank you for answering!
I'll read it!
kawamura
So is this still an issue?
