I am using BCM920737TAG board for software development. I did configured puart port and sending data on Tx. I am capturing data by using Saleae logic analyzer and I observed that some times the data has framing error. Any ideas?
Peripheral UART (SPI1, SPI2, I2C) is (are) shutdown in sleep. So the application has to disable sleep during the time data is being transmitted/received. See puart.h for a couple of macros that can be used to determine if the RX/TX FIFOs have data.
