SDK: 2.1.
Tag: 920737.
app: OTA hello-sensor.
Security: pass key failure at SDK2.1.1
Problem:
Test on passkey security but BT connection is always on. It is claimed that
the bug will be fixed in release SDK2.2. So would like to double check when will
it be released? And I check the old SDK, it seems, it's working in old version v2.0
but currently version is not working.
the other question is, if the hello sensor device has 4 master handset there, if first one
is connected with passkey, and afterwards it can auto be on with BT slave. How about
other new three attempt on BT connection? Do they need to enter passkey or they can connect
the device without input passkey? TKS
BTWi-Fi Bridging
Debug
SDK 2.X
Security
We had hoped to get SDK 2.2 out before the Holiday, but it looks like the release will be delayed at least another week. Our apologies for the inconvenience.
As for the second part of your question, I do not understand what a 4 master handset use case consist of, thinking maybe you meant to say single master with multiple slaves, would each slave need to enter a passkey once the function is working correctly. If this was the question, then yes, I believe you are correct.
