SDK:WICED-Smart-SDK-2.0.1
Module:20736
Basing on hello_client, customer is developing their own application, however once customer board is powered on, following logs can be found:
ASSERT, , L#0, stat=0x20EF08
ÃASSERT, , L#0, stat=0x20EF08
Questions:
1. What's the reason to output those logs?
2. Are there some problems on customer codes? If yes, how to fix them?
Thanks!
The customer application RAM size is too big, once lower the application RAM size, those logs are gone. thanks!
Can we take a step back and let us know how the customer configure his HW setup?
I also noted that the customer is using an outdated SDK version. Can he update it to 2.2.3?
