Please check if the installer has been downloaded completely.
It should be 263,941,240 byte.
And please also check the location you tried to install.
Please do not use multi-byte character in the install path.
MichaelF_56
These are in the process of being updated.
I can't install it. The error is Please select another location to extract the installer to:.
I choose a few locations but it can't.
What could be the problem? I use windows 7.
Regards.
This issue often occurs when you are connected through a VPN of some sort and the file does not finish downloading, yet appears to be finished.
Check the file size of the Windows installer download.  It should be in the 230MB range if I recall.
This happens alot to our internal employees when they connect to our network via the VPN, then try to download the SDK.  Disconnecting from the VPN and retrying almost always works.
apalmer
