It was mentioned in the manual that there will be a plastic component.I am not sure what to be removed.can someone tell me whether i have to remove anything or is it already removed
Debug
- wiced sense
Correct. If the battery is missing as shown in the picture, the plastic peice is definitely gone and most likely on the floor under your desk 🙂
so no problem with that ,right?
But when i press the wakeup button,the iphone is not detecting and the leds on the tag are also not glowing.Please help me out with this
The battery dies quickly in these devices. You may need a new one. Also, make sure the polarity is correct and the battery is seated correctly in the device.
i didnt even use once
+ve outside right?
Can't recall. It can only fit in there two ways, try both. If damaged, arrange an RMA/return with someone in the local sales channel There are many thousands of these in circulation and normally people can get them running within a minute or so using the instructions that are included with the kit.
Found a picture here: WICED SENSE Kit BLOG
thank you.battery was the problem
In the project creation video they are compiling a source code into the tag,right?
what is the application of it?
Now i would like to create a small application like whenever temperature rises above a certain value.i would like to receive a message .can u guide me for that?
A picture of the plastic tab is shown here in this other thread. It's obvious your's has already been removed.
