- Email to a Friend
I've downloaded a program with a patch "additional_advertisement_control.a" to use "bleprofile_notifyAdvPacketTransmissions". I've found a bug that I cannot solved. Therefore, I removed that patch.
After that download, I've tried to download original sample programs (such as hello_sensor") to the WICED Sense, but it always malfunctions when it advertises (Advertisement start for a few milliseconds and stop. PC cannot pair with it). Seems like the patch in the previous download affects consequent downloads.
I have another WICED Sense that is not affected by that patch. Testing of hello_sensor on that device has no problem at all.
I have followed WICED Sense recovery procedure, but it didn't help me.
How can I solved this problem?
SDK 2.X
WICED Sense
- patch
- recovery issue
- Email to a Friend
Yes, it was recovered somehow after I download many different version of my code.
I'm not sure, but it seems to be related to this line of code
bleprofile_regTimerCb(print_time_and_kill, NULL);
Instead of NULL, I should use a blank function instead.
Calling of NULL may generate inconsistent behavior as I observed.
- Email to a Friend
You should do another recovery, but download the wiced_sense application instead from the SDK.
In hindsight, the sense kit is more of a demo kit than anything else. For all product development, the TAG3 board
is still the way to go.
- Email to a Friend
Any luck? Can you recover your sense board?
- Email to a Friend
