I've been trying to get the interrupt working for a button press using the WICED Sense tag board  and the SDK 2.2.0 however for some reason the interrupt only works when the lower button is pressed. The function handler is
// Three Interrupt inputs (Buttons) can be handled here.
// If the following value == 1, Button is pressed. Different than initial value.
// If the following value == 0, Button is depressed. Same as initial value.
// Button1 : value&0x01
// Button2 : (value&0x02)>>1
// Button3 : (value&0x04)>>2
void rtls_beacon_interrupt_handler(UINT8 value)
where value contains which button is pressed. If the lower button is pressed, value = 0b00000001. The problem is the top button does not trigger the interrupt at all.
OK I found the issue since only having one button functional didn't make any sense.
Any asterisks here such as " *_db.c " mean anything can be contained there since everyone's naming will be different.
Identifying the issue
When using the WICED Smart Designer tool to generate new code you select "button" to enable buttons in your project, however button interrupts are only enabled on the "bottom" button (Button1-SW4 in the scematic PDF or K1 in the Mentor Graphics layout). Originally this single button is enabled by setting the values in the GPIO config found in the generated *_db.c file:
// Following structure defines GPIO configuration used by the application
const BLE_PROFILE_GPIO_CFG test_gpio_cfg =
        GPIO_PIN_WP,                               // This need to be used to enable/disable NVRAM write protect
        GPIO_PIN_BATTERY, GPIO_PIN_BUTTON, GPIO_PIN_LED, GPIO_PIN_BUZZER,
        -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1 // Other GPIOs are not used
    /*.gpio_flag =*/
        GPIO_SETTINGS_WP,
        GPIO_SETTINGS_BATTERY, GPIO_SETTINGS_BUTTON, GPIO_SETTINGS_LED, GPIO_SETTINGS_BUZZER,
        0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
Then the GPIO is initialized in the *_create() function:
bleprofile_GPIOInit(bleprofile_gpio_p_cfg);
Then the interrupt is registered, also in the *_create() function:
bleprofile_regIntCb((BLEPROFILE_SINGLE_PARAM_CB) rtls_beacon_interrupt_handler);
Fixing the issue
In order to fix the issue we need to define both buttons in the *_gpio_cfg struct. The define "GPIO_PIN_BUTTON" equates to 0 so I opted to use the gpio driver enums instead which equate GPIO_PIN_P0 to 0 and GPIO_PIN_P4 to 4 (gpiodriver.h is already included at the top of the file).
Order does not matter in the struct, simply match them in the same slots (ie. GPIO_PIN_P0 is at index 2, GPIO_SETTINGS_BUTTON is also at index 2 and so on).
        GPIO_PIN_BATTERY,
        GPIO_PIN_P0,
        GPIO_PIN_P4,
        GPIO_PIN_LED,
        GPIO_PIN_BUZZER,
    /*.gpio_flag =*/
        GPIO_SETTINGS_WP,
        GPIO_SETTINGS_LED,
Then comment out the function call "bleprofile_regIntCb()" in your *_create() function and add instead:
// Register for interrupts from GPIOs
UINT16 masks[3] = {(1 << 4) | (1 << 0), 0 , 0};
gpio_registerForInterrupt(masks, test_gpio_interrupt_handler, 0);
Make sure to include " *_gpio_interrupt_handler " as a new function to replace " *_interrupt_handler ":
*               Function Prototypes
static void test_gpio_interrupt_handler(void* unused, UINT8 gpio);
*               Function Definitions
// The GPIO interrupt handler.
    switch(gpio)
    case GPIO_PIN_P4:
        // Do whatever when button is pressed.
        break;
    case GPIO_PIN_P0:
        break;
    default:
        break;
Alternatively
Remove any references to buttons in the gpio config struct and configure the pins separately after registering the gpio interrupt using:
gpio_configurePin(GPIO_PIN_P0 / 16, GPIO_PIN_P0 % 16, GPIO_EN_INT_RISING_EDGE, GPIO_PIN_OUTPUT_LOW);
gpio_configurePin(GPIO_PIN_P4 / 16, GPIO_PIN_P4 % 16, GPIO_EN_INT_RISING_EDGE, GPIO_PIN_OUTPUT_LOW);
If I goofed in the explanation, all of this is cobbled together from the WICED Sense demo app in the SDK.
MichaelF_56
Only one of the two buttons on the WICED Sense device is functional.
    /*.gpio_flag =*/
        GPIO_SETTINGS_WP,
Fixing the issue
        GPIO_PIN_BATTERY,
        GPIO_PIN_P0,
        GPIO_PIN_P4,
        GPIO_PIN_LED,
        GPIO_PIN_BUZZER,
    /*.gpio_flag =*/
        GPIO_SETTINGS_WP,
        GPIO_SETTINGS_LED,
    switch(gpio)
    case GPIO_PIN_P4:
        break;
    case GPIO_PIN_P0:
        break;
    default:
        break;
Alternatively
