In general, the device's name is defined in the field "local_name" of the data structure BLE_PROFILE_CFG and launched by the function "bleapp_set_cfg".
If I will identify the different device's name in the same firmware, how to change the device's name by function call?
Thanks!
Jack Huang
See hello_sensor sample app, in particular:
else
// total length should be less than 31 bytes
BLE_ADV_FIELD adv[3];
// flags
adv[0].len = 1 + 1;
adv[0].val = ADV_FLAGS;
adv[0].data[0] = LE_LIMITED_DISCOVERABLE | BR_EDR_NOT_SUPPORTED;
adv[1].len = 16 + 1;
adv[1].val = ADV_SERVICE_UUID128_COMP;
memcpy(adv[1].data, db_pdu.pdu, 16);
// name
adv[2].len = strlen(bleprofile_p_cfg->local_name) + 1;
adv[2].val = ADV_LOCAL_NAME_COMP;
memcpy(adv[2].data, bleprofile_p_cfg->local_name, adv[2].len - 1);
bleprofile_GenerateADVData(adv, 3);
you can use your own string instead of bleprofile_p_cfg->local_name. And you may want to write the same string to the local name characteristic too.
