There are many function like ble_trace0 ble_trace1 in WICED-Smart-SDK-1.1.0.
This kind of function using a UART output is correct?
Download UART can be selected as ble_trace0 output UART ? or we shoud config orther UART for the function output?
I use Bluetooth Evaluation Board BCM920732EVAL_Q32_P3.
Thank you very much for your answer!
Both UARTs (peripheral and HCI) can be used for ble_tracex functions.
To select the UART edit the file:
\WICED-Smart-SDK\Wiced-Smart\spar\common\spar_init.c
and find this section:
void SPAR_APP_SETUP(void)
bleapp_pre_init = application_init;
bleapp_trace_enable = BLE_TRACE_UART_HCI; // Change back to
// BLE_TRACE_UART_PERIPHERAL
// to route traces to peripheral
// UART
