There are many function like ble_trace0 ble_trace1 in WICED-Smart-SDK-1.1.0.
This kind of function using a UART output is correct?
Download UART can be selected as ble_trace0 output UART ? or we shoud config orther UART for the function output?
I use Bluetooth Evaluation Board BCM920732EVAL_Q32_P3.
Thank you very much for your answer!
Both UARTs (peripheral and HCI) can be used for ble_tracex functions.
To select the UART edit the file:
\WICED-Smart-SDK\Wiced-Smart\spar\common\spar_init.c
and find this section:
void SPAR_APP_SETUP(void)
bleapp_pre_init = application_init;
bleapp_trace_enable = BLE_TRACE_UART_HCI; // Change back to
// BLE_TRACE_UART_PERIPHERAL
// to route traces to peripheral
// UART
// UART
I have another question ,Please give some tips!
The explanation for the Timer in datasheet is :
Normal timer has a resolution of one second.
Fine timer can be configured in the device configuration to be as low as 12.5 milliseconds.
Then I use the timer is:
the fine_timer_interval in BLE_PROFILE_CFG is 5000;
void time_cb(UINT32 value)
puart_print("t!\r\n");
void fint_time_cb(UINT32 value)
puart_print("f_t!\r\n");
bleprofile_regTimerCb(time_cb,fine_time_cb);
bleprofile_StartTimer();
The Output timing of “t” and “f_t” is not:
“t” :Output once every 1 seconds
“f_t” :Output once every5 seconds
Please give me some tips!Thanks!
Please refer appFineTimer.
