I want to include a simple fixed point math header file. It has no additional includes and you only have to specify if the system has 128bit integer support. However, using certain functions causes the linker to throw the following error:
"undefined reference to '__aeabi_ldivmod'"
We can stop this error if we change any INT64 references in the file to INT32. Of course, if we do this many calculations overflow. I've attached the header file just in case. Is there a known solution to this issue?
SDK 2.X
WICED Sense
Add these to your library and you should compile just fine:
typedef long long int int64_t; | |
typedef unsigned long long int uint64_t; |
Jacob
Hi Jake,
I actually modified this such that int64_t is now INT64 - I mistakenly attached the original version.
In any case, I'll give this a try and see what happens.
Unfortunately we are still seeing the same error.
I just tested on my end and it compiles just fine. Only change made was in the typedefs as you said you had already done.
I'm on SDK 2.2.3.
Only changes made to the file you attached:
Jacob
