Hi ,
I tried to install Wiced Smart Ide using WICED-Smart-SDK-2.2.1-IDE-Installer.bin it showed some error java is not present ..
Then i installed jave open jdk & i installed same it installed correctly but when i lauch WICED Smart IDE it shows Some Error & creates log file
Waiting for reply..
I succesfully installed WICED Smart IDE. also created peripheral device with some services.
But now i want to configure WICED smart TAG as a CENTRAL device..
And there is no example application i seen for CENTRAL DEVICE..
Can anybody please provide some example code & reference..
Did you get the error msg saying you need to "install a VM prior to running this program"?
Then you need to install Java SE from the below link:
http://www.oracle.com/technetwork/java/javase/downloads/index.html
I have a 14.04 Ubuntu 32-bit machine and I managed to resolve the above issue, successfully installed WICED, launched and downloaded the hello_sensor app onto my tag3.
Take a look at the following thread: Testing Master and Slave Roles
Or this one, which also references the thread above: How to setting Central & Peripheral Roles together.
can you create another case on your query on central, and close this current case?
ok
