can i set the parity of the peripheral uart to even? Haven't found it in the API
Peripherhal UART
Unfortunately, only Baud Rate and Flow Control can be set for the Peripheral UART (within BLE_PROFILE_PUART_CFG).
The hardware supports parity, but the firmware hardcodes it to no parity always.
We will consider providing a new API to set parity within the next release of the SDK.
Hi, do you have a release date for the new SDK. Will it be implemented for sure?
At the moment i can't use the chip, because i have to pair the chip with our current modules and i need even parity.
At this point, SDK 2.0.1 is still relatively brand new.
I'm not sure what the release date will be for the next rev of this SDK.
Can you check? It's important as it's breaking some applications connecting to serial ports where owner can't re-configure the remote serial port.
The firmware team was able to come up with a patch that may resolve the issue with fixed parity on the UART.
After invoking puart_init(), try adding the following:
// Defaults
UINT16 lcr = P_UART_LCR_TXOEN_MASK | P_UART_LCR_RXEN_MASK | P_UART_LCR_RTSOEN_MASK;
if(odd_parity_needed)
lcr |= (P_UART_LCR_PEN_MASK); //////// Set the parity enable bit. Default parity is odd.
else
lcr |= (P_UART_LCR_PEN_MASK | P_UART_LCR_EPS_MASK); //////// Set parity enable bit and enable even parity
// Now program the uart register with the new configuration values.
P_UART_LINE_CONTROL(lcr);
