I am trying to implement some RF test software so I can send my product to a test house. I need to be able to generate a continuous frequency at differing powers and modulation. The Set_Tx_Carrier_Frequency_ARM command seems to be ideal for my needs, but it doesn't work. Can anyone tell me the correct command sequence I should be sending using hcitool?
This is running on a headless Raspberry Pi CM3 so no way of using any GUI based packages, just the commandline.
Hi AnCh_3708191 ,
Please have a look at the commands here: HCI-Based Bluetooth Testing
Make sure you get a success response for HCI reset command first at the start.
Anjana
Hi AnCh_3708191 ,
Anjana
