Hi all.
I try to test the ancs service with watch example. (with BCM 20737 DK)
When I download the application firmware and connect with my iPhone, the bonding is completed.
However, when I check it with terminal (putty), there is no ancs message.
when I get a message, call, and etc. , it doesn't display anything.
Is there any setting steps for displaying ancs service?
+ when I check the watch_db.c there is no information about ancs service.
please check it. (I didn't change any codes)
Have a good day
Kyu.
(for other developers)
OK. I got the solution from Broadcom support team.
Just put this line ancs_client_initialize function on ancs_client.c
    ancs_client_initialize_complete_callback = initialize_complete_callback;
    memset (&ancs_client, 0, sizeof (ancs_client));
    ancs_client.ancs_e_handle=e_handle;     <--- this
    ancs_client.state =      ANCS_CLIENT_STATE_WAIT_READ_ANCS_CHARACTERISTIC;
It is working well now.
Jun-Kyu
This is a first time to use BCM solution.
Even if the question looks stupid, please help me.
Can you use the "Trace" feature of the IDE instead? Check out Quick Start Guide (QSG202.pdf) under the /Doc folder on how to do that. Let me know whether can you see traces.
BoonT_56
Thanks for reply.
This is a original log. !
ancs_client.connection_up: 020100200400 64onded 0 handle 64
@$*#04FF86F700920110000002FA240000000000078633000000000007E6200000000000078E1E0000000080E4310E459C776A80E4350E4000D1C280E4390E2000010280E43D0E0004000000078E1E0000000000E579022000010200E57D020004000080034E1B1400000080034E1B1800000080034E1B1C00000080036E1B0000000000075A3300000000@$*#04FF0EF700920101008004D61D02000000@$*#04FF16F700920102000007F610FA0005000007FA1001000000@$*#04FF0EF7009201010080041A1D00000000@$*#04FF0EF7009201010080041A1D00000000Watch: encryption changed: on 020100200400
@$*#04FF2EF7009201050080041A1D0000000080041A1D0000000080041A1D0000000080041A1D00ancs_client, bond result 03: bonded: 6a779c45c2d1 type 1 bonded 1 handle 64
@$*#04FF26F7009201040080E49D100300000080E4E5100300000000E5E5030300000000E5490408watch_write_handler: NVRAM write:0018te = 15150
watch_write_handler: len:2 handle 0014
write_handler: hid_report_client_configuration: 0001
@$*#04FF26F7009201040000E575041400000000E575041400000080033A1B1400000000E5750414000000watch_write_handler: len:2 handle 001c
@$*#04FF26F7009201040000E575041C00000000E575041C00000080033A1B1400000000E575041C000000@$*#04FF16F700920102000007F610FA0005000007FA1001000000@$*#04FF16F700920102000007F610FA0005000007FA1001000000@$*#04FF16F700920102000007F610FA0005000007FA1001000000@$*#04FF16F700920102000007F610FA0005000007FA1001000000@$*#04FF16F700920102000007F610FA0005000007FA1001000000@$*#04FF16F700920102000007F610FA0005000007FA@$*#04FF0EF7009201010000E5490B6400000010FA0005000007FA100100000064
In this log, It looks like that it doesn't make a new line for logging. So I attach other log that I modify.
In the modify log, I didn't changed any source code but log message.
Also, I found that it cannot search the notification source characteristic  in ancs_client_process_rsp function.
It just find control point characteristic.
watch_connection_up: 020100200400 type 1 bonded 0 handle 64
Watch: sending security request
@$*#04FF86F700920110000002FA240000000000078633000000000007E6200000000000078E1E0000000080E4310E459C776A80E4350E4000D1C280E4390E2000010280E43D0E0004000000078E1E0000000000E579022000010200E57D020004000080034E1B1400000080034E1B1800000080034E1B1C00000080036E1B0000000000075A3300000000@$*#04FF16F700920102000007F610FA0005000007FA1001000000@$*#04FF0EF700920101008004D61D02000000@$*#04FF0EF7009201010080041A1D00000000@$*#04FF0EF7009201010080041A1D00000000Watch: encryption changed: on 020100200400
ANCS encryption changed:00 bonded:1
@$*#04FF2EF7009201050080041A1D0000000080041A1D0000000080041A1D0000000080041A1D000000008004521D00000000Watch: bonded: 6a779c45c2d1 type 1 bonded 1 handle 64
NVRAM write:0018
NVRAM write:6
Service Search
@$*#04FF46F7009201080080E49D100300000080E4E5100300000000E5E5030300000000E549040800000000E575041400000000E575041400000080033A1B1400000000E5750414000000Client Rsp len:12, attr_len:6
s:0001 e:0005 uuid:1800
s:0006 e:0009 uuid:1801
Service Search s_hdl:000a, e_hdl:ffff
@$*#04FF26F7009201040000E575041C00000000E575041C00000080033A1B1400000000E575041C000000Client Rsp len:20, attr_len:20
000a e:000e uuid
6643ae107948f8a59145b4bb781e61d0
Service Search s_hdl:000f, e_hdl:ffff
s:000f e:0012 uuid:180f
s:0013 e:0018 uuid:1805
Service Search s_hdl:0019, e_hdl:ffff
0019 e:0022 uuid
d0002d121e4b0fa4994eceb531f40579
#### ANCS service founded!!!!####                 <------ I added this log.
Service Search s_hdl:0023, e_hdl:ffff
0023 e:002e uuid
dcf855ad02c5f48e3a43360f2b50d389
Service Search s_hdl:002f, e_hdl:ffff
Client Rsp len:0, attr_len:0
###### GATT client init successed####                       <------ I added this log.
state = 15:00:177.(128/256) (Day) 71,  Reason:0
ANCS Client Rsp len:10, attr_len:0 state = 15
state = 15
ANCS client process rsp len = 0a    ####                                     <------ I added this log.
ANCS Client Rsp state = 15
ANCS Client Rsp len:21, attr_len:21 state = 15
!!!!!permission:88   !!!!                                                    <------ I added this log.
!!!!! handle:001b   !!!!        <------ I added this log.
@@@@ afdbd9b2198a849e145f3d8d169               <------ I added this log.   "ble_tracen (&data[i + 5], 16);"  (It looks be cut.)
control point hdl:001b
state = 15
ANCS Client Rsp len:0, attr_len:0 state = 15
###### ANCS client init successed####                      <------ I added this log.
state = 00
ANCS Client Rsp state = 00
Hello JunKyu,
We observed the same error and are meeting with the developers tomorrow to seek a resolution.
Which iOS version are you using on the iPhone?
Can you try iOS 9.2 to see if it works?
Thank you.
JT
Hi JT.
It doesn't work on iOS 9.2 still.
(Also, the log is looks same with before)
Jun-Kyu
Below is a log with on iphone5 with iOS9.2. Towards the end of the log, a button-press was registered while I pause and un-pause the music play on the phone. After that, I also did a time-date change. For your reference...
14:23:02 - 14:23:02 - 0018
14:23:02 - 14:23:02 - 020300002a
14:23:02 - 14:23:02 - 4d792057617463680000000000000000
14:23:02 - 14:23:02 - 020500012a
14:23:02 - 14:23:02 - c000
14:23:02 - 14:23:02 - 020700042a
14:23:02 - 14:23:02 - 060006000a003200
14:23:02 - 14:23:02 - 0118
14:23:02 - 14:23:02 - 1218
14:23:02 - 14:23:02 - 020b004a2a
14:23:02 - 14:23:02 - 11010000
14:23:02 - 14:23:02 - 060d004e2a
14:23:02 - 14:23:02 - 040f004c2a
14:23:02 - 14:23:02 - ff
14:23:02 - 14:23:02 - 0211004b2a
14:23:02 - 14:23:02 - 05010906a101850175019508050719e0
14:23:02 - 14:23:02 - 29e71500250181029501750881039505
14:23:02 - 14:23:02 - 75010508190129059102950175039103
14:23:02 - 14:23:02 - 95067508150026ff000507190029ff81
14:23:02 - 14:23:02 - 00c0050c0901a1018502751095021501
14:23:02 - 14:23:02 - 268c0219012a8c028160c0
14:23:02 - 14:23:02 - 1213004d2a
14:23:02 - 14:23:02 - 0000000000000000
14:23:02 - 14:23:02 - 0101
14:23:02 - 14:23:02 - 0e17004d2a
14:23:02 - 14:23:02 - 0102
14:23:02 - 14:23:02 - 121b004d2a
14:23:02 - 14:23:02 - 0201
14:23:02 - 14:23:02 - 0318
14:23:02 - 14:23:02 - 0a1103062a
14:23:02 - 14:23:02 - 0218
14:23:02 - 14:23:02 - 041104062a
14:23:02 - 14:23:02 - 0418
14:23:02 - 14:23:02 - 021105072a
14:23:02 - 14:23:02 - 0f18
14:23:02 - 14:23:02 - 02f207192a
14:23:02 - 14:23:02 - 64
14:23:02 - 14:23:02 - 0a18
14:23:02 - 14:23:02 - 021108502a
14:23:02 - 14:23:02 - 025c0a20200100
14:23:02 - 14:23:02 - 020106030303180319c00009094d7920
14:23:02 - 14:23:02 - 5761746368
14:23:02 - 14:23:02 - 020a04
14:23:02 - 14:23:02 - 0100
14:23:02 - 14:23:02 - a834dc448f66
14:23:02 - 14:23:02 - watch_create()
14:23:02 - 14:23:02 - 1.00
14:23:02 - 14:23:02 - 02010507021218021819200319c00009
14:23:02 - 14:23:02 - 094d79205761746368
14:23:02 - 14:23:02   Trace Decoding Error - Could not find line number 314
14:23:02 - 14:23:02   bd_addr[1:0] = 68A2 00
14:23:02 - 14:23:02   GPIO 0001 (11)
14:23:02 - 14:23:02   GPIO 0000 (104)
14:23:02 - 14:23:02   GPIO 0015 (20)
14:23:02 - 14:23:02   GPIO 0014 (1003)
14:23:02 - 14:23:02   GPIO 0028 (2001)
14:23:02 - 14:23:02   Interrupt mask[0,1]:0001 0000
14:23:02 - 14:23:02   Interrupt mask[2]:0000
14:23:02 - 14:23:02   GPIO_WP:OFF= 00
14:23:02 - 14:23:02   GPIOBTN1:OFF=1,INT:0
14:23:02 - 14:23:02   GPIOBAT
14:23:02 - 14:23:02   GPIO_LED:OFF=1
14:23:02 - 14:23:02   GPIO_BUZ:OFF=0
14:23:02 - 14:23:02   bleprox_ll_alt_hdl:0311
14:23:02 - 14:23:02   bleprox_ia_alt_hdl:0411
14:23:02 - 14:23:02   bleprox_tx_pw_hdl:0511
14:23:02 - 14:23:02   Battery level: 0/100
14:23:02 - 14:23:02   Battery level: 1/100
14:23:02 - 14:23:02   LEDBlink(250, 250)
14:23:02 - 14:23:02   LEDBlink Num = 1
14:23:02 - 14:23:02   Fine Timer(100 ms, 10/sec)
14:23:02 - 14:23:02   Fine TImer tick 8
14:23:02 - 14:23:02   Normal Timer(1 s, 80 tick)
14:23:02 - 14:23:02   connDown
14:23:02 - 14:23:02   BLE_high_un_adv:timer(1)
14:23:02 - 14:23:02   LL_Alert_Level:1
14:23:02 - 14:23:02   TimersKilled
14:23:02 - 14:23:02   Fine TImer tick 0
14:23:02 - 14:23:02   BLE_high_un_adv:timer(0)
14:23:03 - 14:23:03   LEDBlink(5, 250)
14:23:03 - 14:23:03   LEDBlink Num = 1
14:23:03 - 14:23:03   BUZBeep(0)
14:23:04 - 14:23:04   LEDBlink(5, 250)
14:23:04 - 14:23:04   LEDBlink Num = 1
14:23:04 - 14:23:04   BUZBeep(0)
14:23:06 - 14:23:06   LEDBlink(5, 250)
14:23:06 - 14:23:06   LEDBlink Num = 0
14:23:11 - 14:23:11   LEDBlink(5, 250)
14:23:11 - 14:23:11   LEDBlink Num = 0
14:23:16 - 14:23:16   LEDBlink(5, 250)
14:23:16 - 14:23:16   LEDBlink Num = 0
14:23:21 - 14:23:21   LEDBlink(5, 250)
14:23:21 - 14:23:21   LEDBlink Num = 0
14:23:26 - 14:23:26 - watch_connection_up: 668f44dc34a8 type 1 bonded 1 handle 64
14:23:26 - 14:23:26 - 0000
14:23:26 - 14:23:26 - ancs_client.connection_up: 668f44dc34a8 64
14:23:26 - 14:23:26 - device bonded
14:23:26 - 14:23:26   Connection is UP.
14:23:26 - 14:23:26   profile idle timer stop
14:23:26 - 14:23:26   connUp
14:23:26 - 14:23:26   noAdv
14:23:26 - 14:23:26   bleprox_connUp: bda[5..2] = 50 42 26 28
14:23:26 - 14:23:26   bleprox_connUp: bda[1..0], handle = 40 81, 0040
14:23:26 - 14:23:26   puba[5..2] = 66 8f 44 dc
14:23:26 - 14:23:26   puba[1..0] = 34A8 00
14:23:26 - 14:23:26   blebat_connUp[5:2]: 66 8f 44 dc
14:23:26 - 14:23:26   blebat_connUp[1:0]: 34a8 00
14:23:26 - 14:23:26   0014:NOT_OFF
14:23:26 - 14:23:26   0018:NOT_OFF
14:23:26 - 14:23:26   001c:NOT_OFF
14:23:26 - 14:23:26   All Notifications Off
14:23:26 - 14:23:26   profile idle timer(0)
14:23:26 - 14:23:26   LEDBlink(5, 250)
14:23:26 - 14:23:26   LEDBlink Num = 0
14:23:27 - 14:23:27   smp timer started 00
14:23:28 - 14:23:28   SMPTmrRef
14:23:29 - 14:23:29 - Watch: encryption changed: on 668f44dc34a8
14:23:29 - 14:23:29 - ANCS encryption changed:00 bonded:1
14:23:29 - 14:23:29 - Watch: bonded: 504226284081 type 1 bonded 1 handle 64
14:23:29 - 14:23:29 - NVRAM write:0018
14:23:29 - 14:23:29 - ancs_client, bond result 03
14:23:29 - 14:23:29 - NVRAM write:6
14:23:29 - 14:23:29 - Service Search
14:23:29 - 14:23:29   SMPTmrRef
14:23:29 - 14:23:29   SMPTmrStp
14:23:29 - 14:23:29   bleprox, bond result 03
14:23:29 - 14:23:29   NVRAM write:0003
14:23:29 - 14:23:29   blebat, bond result 03
14:23:29 - 14:23:29   NVRAM write:0000
14:23:29 - 14:23:29 - Client Rsp len:12, attr_len:6
14:23:29 - 14:23:29 - s:0001 e:0005 uuid:1800
14:23:29 - 14:23:29 - s:0006 e:0009 uuid:1801
14:23:29 - 14:23:29 - Service Search s_hdl:000a, e_hdl:ffff
14:23:29 - 14:23:29 - Client Rsp len:20, attr_len:20
14:23:29 - 14:23:29 - 000a e:000e uuid
14:23:29 - 14:23:29 - 6643ae107948f8a59145b4bb781e61d0
14:23:29 - 14:23:29 - Service Search s_hdl:000f, e_hdl:ffff
14:23:29 - 14:23:29 - Client Rsp len:18, attr_len:6
14:23:29 - 14:23:29 - s:000f e:0012 uuid:180f
14:23:29 - 14:23:29 - s:0013 e:0018 uuid:1805
14:23:29 - 14:23:29 - s:0019 e:001d uuid:180a
14:23:29 - 14:23:29 - Service Search s_hdl:001e, e_hdl:ffff
14:23:29 - 14:23:29 - 001e e:0027 uuid
14:23:29 - 14:23:29 - d0002d121e4b0fa4994eceb531f40579
14:23:29 - 14:23:29 - Service Search s_hdl:0028, e_hdl:ffff
14:23:29 - 14:23:29 - 0028 e:0033 uuid
14:23:29 - 14:23:29 - dcf855ad02c5f48e3a43360f2b50d389
14:23:29 - 14:23:29 - Service Search s_hdl:0034, e_hdl:ffff
14:23:29 - 14:23:29 - Client Rsp len:0, attr_len:0
14:23:29 - 14:23:29 - GATT Client Rsp len:7, attr_len:7
14:23:29 - 14:23:29 - service_changed hdl:0008
14:23:29 - 14:23:29 - TIME Client Rsp state:1 len:14 attr_len:7
14:23:29 - 14:23:29 - current_time hdl:0015
14:23:29 - 14:23:29 - TIME Client Rsp state:2 len:4 attr_len:4
14:23:30 - 14:23:30 - current_time ccc hdl:0016
14:23:30 - 14:23:30 - TIME Client Rsp state:3 len:0 attr_len:0
14:23:30 - 14:23:30 - TIME Client Rsp state:4 len:2120585 attr_len:19
14:23:30 - 14:23:30 - TIME Notification: attr_len:19 len:2120585
14:23:30 - 14:23:30 - (Date) 45237/72/128
14:23:30 - 14:23:30 - (Time) 105:00:177.(128/256) (Day) 71,  Reason:0
14:23:30 - 14:23:30 - state = 15
14:23:30 - 14:23:30 - ANCS Client Rsp len:10, attr_len:0 state = 15
14:23:30 - 14:23:30 - ANCS Client Rsp state = 15
14:23:30 - 14:23:30 - ANCS Client Rsp len:21, attr_len:21 state = 15
14:23:30 - 14:23:30 - control point hdl:0020
14:23:30 - 14:23:30 - ANCS Client Rsp len:0, attr_len:0 state = 15
14:23:30 - 14:23:30 - watch_write_handler: NVRAM write:0018
14:23:30 - 14:23:30 - state = 00
14:23:30 - 14:23:30 - ANCS Client Rsp state = 00
14:23:30 - 14:23:30 - watch_write_handler: len:2 handle 0014
14:23:30 - 14:23:30 - write_handler: hid_report_client_configuration: 0001
14:23:30 - 14:23:30   WriteCb: handle 0014
14:23:30 - 14:23:30   0014:NOT_ON
14:23:30 - 14:23:30   WriteCb: handle 0000
14:23:30 - 14:23:30 - watch_write_handler: len:2 handle 001c
14:23:30 - 14:23:30   WriteCb: handle 001c
14:23:31 - 14:23:31   LEDBlink(5, 250)
14:23:31 - 14:23:31   LEDBlink Num = 0
14:23:36 - 14:23:36   LEDBlink(5, 250)
14:23:36 - 14:23:36   LEDBlink Num = 0
14:23:38 - 14:23:38 - (INT)But1:1 But2:0 But3:0 handle:64 CCC:1
14:23:41 - 14:23:41 -
14:23:41 - 14:23:41   LEDBlink(5, 250)
14:23:41 - 14:23:41   LEDBlink Num = 0
14:23:45 - 14:23:45 - (INT)But1:1 But2:0 But3:0 handle:64 CCC:1
14:23:46 - 14:23:46 -
14:23:46 - 14:23:46   LEDBlink(5, 250)
14:23:46 - 14:23:46   LEDBlink Num = 0
14:23:51 - 14:23:51   LEDBlink(5, 250)
14:23:51 - 14:23:51   LEDBlink Num = 0
14:23:56 - 14:23:56   LEDBlink(5, 250)
14:23:56 - 14:23:56   LEDBlink Num = 0
14:24:01 - 14:24:01   LEDBlink(5, 250)
14:24:01 - 14:24:01   LEDBlink Num = 0
14:24:02 - 14:24:02 - 01
14:24:02 - 14:24:02 - 0100
14:24:02 - 14:24:02   Battery level: 0/100
14:24:05 - 14:24:05 -
14:24:05 - 14:24:05 - Watch Notification handle:15 len:10
14:24:05 - 14:24:05 - TIME Notification: attr_len:21 len:10
14:24:05 - 14:24:05 - (Date) 2016/01/13
14:24:05 - 14:24:05 - (Time) 11:54:05.(3/256) (Day) 134,  Reason:2
14:24:06 - 14:24:06   LEDBlink(5, 250)
14:24:06 - 14:24:06   LEDBlink Num = 0
14:24:11 - 14:24:11   LEDBlink(5, 250)
14:24:11 - 14:24:11   LEDBlink Num = 0
14:24:16 - 14:24:16   LEDBlink(5, 250)
14:24:16 - 14:24:16   LEDBlink Num = 0
14:24:18 - 14:24:18 -
14:24:18 - 14:24:18 - Watch Notification handle:15 len:10
14:24:18 - 14:24:18 - TIME Notification: attr_len:21 len:10
14:24:18 - 14:24:18 - (Date) 2016/01/13
14:24:18 - 14:24:18 - (Time) 14:24:18.(3/256) (Day) 143,  Reason:2
14:24:21 - 14:24:21   LEDBlink(5, 250)
14:24:21 - 14:24:21   LEDBlink Num = 0
14:24:26 - 14:24:26   LEDBlink(5, 250)
14:24:26 - 14:24:26   LEDBlink Num = 0
Thanks boont.
However, ANCS notification characteristic still not active.
(Only, control point is active)
I think, ancs_client_process_rsp in ancs_client.c can not detect notification source characteristic.
and it goes to idle state.
you can check it on your log.
I want show what happen in the ancs_client_rsp function, but I can not check it.
please check it.
Jun-Kyu
신준규
We are still working internally on this and will update when there is a fix.
Dear boont.
Thanks for reply.
Have a good day
Is there anybody here?
I update something like bug.
In the ancs_client.c, I added trace log for checking handle value in the ancs_client_initialize function.
// command from the main app to start search for characteristics
int ancs_client_initialize(UINT16 s_handle, UINT16 e_handle, BLEPROFILE_SINGLE_PARAM_CB initialize_complete_callback)
  ble_trace0("###ANCS INIT START ####\n\r");
    if ((s_handle == 0) || ((ancs_client.ancs_e_handle = e_handle) == 0))
        return FALSE;
    // Functions of this module willl need to receive GATT client callbacks
    leatt_regReadRspCb((LEATT_TRIPLE_PARAM_CB) ancs_client_process_rsp);
    leatt_regReadByTypeRspCb((LEATT_TRIPLE_PARAM_CB) ancs_client_process_rsp);
    leatt_regReadByGroupTypeRspCb((LEATT_TRIPLE_PARAM_CB) ancs_client_process_rsp);
    leatt_regWriteRspCb((LEATT_NO_PARAM_CB) ancs_client_write_rsp);
    ble_trace1("state = %02x", ancs_client.state);
    bleprofile_sendReadByTypeReq(s_handle, e_handle, UUID_ATTRIBUTE_CHARACTERISTIC);
    ble_trace2("*****ANCS request handle value s_hdl:%04x, e_hdl:%04x*****\n\r", s_handle, e_handle);
    return TRUE;
16:02:15 - *****ANCS request handle value s_hdl:001e, e_hdl:0027*****
It looks like, BCM 20737 sends the characteristic discovery request to the iOS(server).  (handle 001e~ 0027)
But in the ancs_client_process_rsp function, 20737 finds only one characteristic for control point, and the attr_len become 0.
and it goes to the IDLE STATE on here. Because ancs_client.current_characteristic_index++; is not executed anymore.
            if (ancs_client.current_descriptor_index == ancs_client.current_characteristic_index)
                ancs_client.state = ANCS_CLIENT_STATE_IDLE;
                (*ancs_client_initialize_complete_callback)(1);
this is a log.
16:02:15 - state = 15
16:02:15 -
16:02:15 -
16:02:15 -
16:02:15 - ANCS Client Rsp len:21, attr_len:21 state = 15
16:02:15 -
16:02:15 - #### data:
16:02:15 - 1f00882000d9d9aafdbd9b2198a849e1                                            <- ANCS_CONTROL_POINT
16:02:15 - 45f3d8d169
16:02:15 - ####
16:02:15 -
16:02:15 - control point hdl:0020
16:02:15 - ***ANCS char num: 1  ****
16:02:15 -
16:02:15 -
16:02:15 -
16:02:15 - ANCS Client Rsp state = 15
16:02:15 -
16:02:15 - ANCS Client Rsp len:0, attr_len:0 state = 15                               <- attr_len become zero
please check it.
Regards, Jun-Kyu
Unfortunately, there is no update to provide at this time.
boont
I am still tracking this internally with the factory. Sorry for the delay.
신준규
Please close this case as you have gotten the fix.
Jun-Kyu
