hi,
I'm using BCm920737TAG
i'have successfully created an application with vendor specific services and characteristics.
i can read wirte using BLE scanner and android.
But anytime after i enable the notify in Android ( with a notify able characteristic) i cannot read or write any other characteristic...
Can someone Help me ?
Do i have to do something else after
bleprofile_sendNotification(HDLC_IR_TEMPERATURE_SERVICE_IR_TEMPERATURE_DATA_VALUE, (UINT8 *)db_pdu.pdu, db_pdu.len);
Thank you
MichaelF_56
I spoke to the developers today about this issue and they asked me to refer you to the WICED Sense Android Source (v1.06) example as we enable notifications for sensor outputs within this application.
They believe that this is most likely a bug within your application and not a firmware issue.
MichaelF_56
I just downlaod the v2.2 of the SDK, and everything works.
