I would like to test the range between BCM920702DG_FLSH dongle and my sensor that has a BCM920732. Do you have a sw utility that will show me the signal strength? Any recommendations on how to perform this test?
Can I set the tx power level on the dongle side? I think I know how to set that on the sensor side.
Hello ppaszkow,
I was referring to no specific document.  I just wanted to point you to ALL of the documents in case you didn't know where they were.
The Bluetooth Trace Tool works on Win7 and Win8.
JT
Hello ppaszkow,
You can download the Bluetooth Trace tool listed below:
There are several other documents that you might find useful here:
WICED Smart Documentation
Let me know if you have further questions.
JT
Thanks for the info.
I downloaded the tool and got it to work thanks to this:
HelloClient.exe reports "Broadcom Bluetooth profile pack for Windows (BTW)..." error
Can you be more specific on the doc I should refer to? I went through most of them already.
Now that I can use the trace tool on Win7 can I pair on Win7 too? So far I was only able to pair and get HelloClient.exe running on Windows 8
Hello ppaszkow,
JT
