Smart Bluetooth
SaEa_4705941
New Contributor II
During evaluation of CYBT-343026, how can I observe the RSSI on windows 10?
I intend to use the development board in classic mode.
Owen_Zhang123
I have confirmed internally, the RSSI inquiry is not support in the current EZ-Serial FW.
SheetalJ
Hi @SaEa_4705941 ,
You can use API wiced_bt_dev_read_rssi() to read the RSSI value. More details can be found in wiced_bt_dev.h file.
SaEa_4705941
New Contributor II
Hi @SheetalJ ,
Thank you for your response. I am trying this with the EZ-Serial.
I used the command /BTQSS every time I query the RSSI of a nearby device, I get R=00 response. I used another EVALUATION board to test as well.
SaEa
Owen_Zhang123
Which version of the EZ-Serial are you using?
As I know, the BT connection only support SPP mode. Once the connection is built, it will enter throughput mode.
So the command is not available now.
SaEa_4705941
New Contributor II
Hi @Owen_Zhang123 ,
The EZ-serial version is E=01010E06 from the reboot event.
I am trying to achieve this for the unconnected state.
Even, when I query the RSSI's from a linux machine only these 2 development boards show up without an RSSI value. I would really  appreciate your support on this.
My aim is to detect the signal strength of multiple Evaluation boards from a host machine.
SaEa
Owen_Zhang123
