SaCo_2181666
First like received
Hi all,
Does BCM20736S support a Random Number Generator? If so, which Wiced API can be used to create a random number?
Sabino
AnjanaM_61
First comment on KBA 5 questions asked First question asked
AnjanaM_61
Hi AnjanaM_61
Thanks for your reply. Yes, I find your links useful.
Please, could you confirm that if I do:
UINT32 rand_nums[4];
ulp_rand(rand_num, 4);
this single call will generate 4 random UINT32 numbers at once?
Sabino
Hi SaCo_2181666
I have seen the implementation only as below :
UINT32 rand1, rand2, init_value, toggle_value;
static ref_clock = 0;
ulp_rand(&rand1, 1);
ulp_rand(&rand2, 1);
Refer to example pwm_tones in WICED SMART ( /WICED-Smart-SDK/Apps/pwm_tones )
Not sure if any other value to the second parameter works .
Anjana
