We could not find API for current SPIFFY 2 pin configuration. Please help below
Application uses SPIFFY 2 only (not UART) – in slave mode. Could we use pin configuration (CS/SCLK/MOSI/MISO – P32/P3/P4/P25) as below:
SPI
Unfortunately not.
Take a look at Table 2 on page 11 of the following: WICED™ Smart Hardware Interfaces
Horizontally, the GPIO options that are noted in black are the valid combinations for these 4 signals.
There is also a code snippet in the document which shows how to initialize SPIFFY2 in the slave role, and how to read and then write a byte to a SPI master.
Unfortunately not.
