Hello i am using the BCM92073X_LE_KIT. In the sdk supplied with this module is a schematic. In the picture attached you will see a green box, within this box you will see numbering beside each pin out in red. can someone tell me what this is?
Regards luke.
ShawnA_01
25 solutions authored 10 solutions authored 5 solutions authored
I'm looking at the 920737TAG03-HWUM100-R.pdf of the SDK 2.2.1 installation, but it does not show a green box.
None the less, the numbers inside your green box indicate the page number where these "net-names" can be seen, i.e. J7 connector Pin number 1 equals "P1", which can then be seen on Pages 2, and 5.
ShawnA_01
