Hi, is it possible to put a new value in the btp file and read it from the application? Let's say, Is it possible to put a value "DLSerialNumber = 1234", generate an hex file starting from the cgs and using the modified btp, flash it on the BCM20736 and read it from the application? Thanks in advance.
BoonT_56
IF you want to insert a serial number, you may do this in any free area of the eeprom by directly changing the HEX file (at your own risk!). Then download it onto the eeprom using ChipLoad.exe.
Firmware security (20732)
BoonT_56
Btp file is a preset configuration to organize say the eeprom during the downloading process. App does not access this after that.
Hi, I don't want, as a matter of fact, manage the btp from the app. I will give a try to the suggested solutions. Thanks.
BoonT_56
