I would like to program Wiced sense to create my own apps.Can someone tell me how to start and where to start?
I would like to invite you to walk through the below. It will give you a better understanding to SENSE as well as some head start to development.
Thank you for your reply.It is a zipped file and i couldnt find any app to open the c/c++ wiced smart ide.
Help please
Use the WICED Smart IDE for Windows: WICED-Smart-SDK-2.1.1-IDE-Installer (Windows)
It's a self-extracting executable.
IN THE VIDEO OF CRAETING A PROJECT,AFTER CREATING THE PROJECT HE HAS DOWNLOADED A FILE(IN THE LAST MIN) REPLACING THE NAME WITH THE WICED_SENSE(FOLDER NAME).THEN HE BUILD IT.BUT I CANT BUILD IT.THERE WERE MANY ERRORS IN .C FILE.HELP PLEASE
and the error is no rule to make target
How about below thread?
in that post,he said to retain the drivers folder.i haven't deleted them.i just copied .so it should work,i guess.but its not working
If your environment is same, it may help.
Compile Error with the Sample Applications on WICED-Smart-SDK-2.1.1 Running on Linux 64-bit
You can also use some AndroidStudio App projects, attached here on some threads.
Instead of Eclipse IDE you can also modify, extend the WICEDSense APK project (I did several times).
ITS WORKING.THANK YOU
