There are samples under WICED SDK for upgrading of application over PUART. Is there a mechanism documented for downloading an application over PUART on a blank part? That is, if an application doesn't exist, download the application from PUART.
Peripherhal UART
Unfortunately there is not, and the only way to program the device is from the SDK, Command line tools, or through one of the programming centers we have enabled, such as Avnet.
First time programming of the part MUST occur over the HCI UART.
Once programmed, there are examples for using the PUART for updates.
Thank you. Is there any document/details for HCI UART programming protocol? I am looking to see if I can program the part from our host, and not have to necessarily hook it up to a PC.
Ok, thank you.
