I got WICED Sensor tag ..
I want to know is it re-programmable ?
if yes then how to program it?
i successfully power up it trough usb..
Shrikrishna
WICED Sense
If a WICED Sense 1 unit (original), you will need to crack open the plastic case so you can access the reset button that's on the internal PCB. Toggling this button will place the unit in programming mode. Once in programming mode, you can program it using the SDK with the USB cable that's provided. On WICED Sense 2, an external reset button is provided.
This is crucial information for beginners. Can this be linked to the Wiced Sense Table of Contents page, or something similarly prominent?
