- Email to a Friend
LE stack does not switch to sleep mode if the fine timer's timeout is set to 12 ms even when the fine timer is stopped.
The current is around 1mA what makes me think that chip is still only in Pause mode.
Sleep Modes
- Email to a Friend
Hello madmax
From the developers:
Please see if the following code snippet resolves your issue:
#include "devicelpm.h"
UINT32 app_queryPowersave(LowPowerModePollType type, UINT32 context)
if (type == LOW_POWER_MODE_POLL_TYPE_SLEEP)
// Always allow sleep and let the FW decide actual sleep time.
return ~0;
// Never allow deep sleep/hid-off.
return 0;
void application_create(void)
// Do all other application initialization here.
// Override default implementation of the app queriable:
bleprofile_queryPowersaveCb = app_queryPowersave;
JT
- Email to a Friend
- Email to a Friend
Hello Lukasz,
Look at the RTC example. Look at P39 for Clear GPIO_Status.
- Email to a Friend
The above answer may apply to other discussion:
Problem with wake up from deep sleep with a timer
but not to this one.
- Email to a Friend
Hello Lukasz,
Apologies, Correct.
This issue is being investigated by the development team.
JT
- Email to a Friend
Hello madmax
return ~0;
return 0;
JT
