I have two problem.
The first,
I developed BLE product using BCM920737TAG-03 and SDK2.2.3 under windows 10.
When it compiled(built), errors was occured as blow.
"makefile:184: recipe for target '../../build/hello_sensor-BCM920736TAG_Q32-rom-ram-Wiced-release/A_20736A1-hello_sensor-rom-ram-spar.cgs' failed"
"Makefile:350: recipe for target 'hello_sensor-BCM920736TAG_Q32' failed"
I confirmed switch setting and any configuration according to Qucik Start Guide.
Everything was correct.
I tried the other desktop installed windows 7.
As a result, it worked very well.
I don't know the difference between windows 7 and windows 10.
Please help me.
The second,
Using desktop installed windows 7, i tried to make WICED sense application.
But, there was no wiced sense item in Make Target window of smart IDE .
In Apps directory, there was wiced sense folder.
How can i build and download wiced sense.
Please, let me know.
Thanks a lot.
SDK 2.X
WICED Sense
Windows
Ver 2.2.3 should be relatively stable on Win10 and I haven't see any feedback otherwise lately.
In your case, the error message (in red) pointed to an issue in the makefile rather than the stability of the SDK
in Win10, although I take note that the same installation in Win7 did not resulted in any compilation issue.
I suggest that you continue to work in Win7 environment and let me quote some make targets from my own SDK (in Win7)
wiced_sense-BCM920737TAG_Q32 download BT_DEVICE_ADDRESS=1234AA4567BB UART=COM23
wiced_sense-BCM920737TAG_Q32 recover UART=COM63
wiced_sense-BCM920737TAG_Q32 build
The last will just build your compilation and not download it onto your board. You may want to acquire a SENSE board if you are truly working on an application for it.
I want to clarify that I used the above targets on my Wiced Sense board, and not the tag3 board.
Thanks your response.
I bought WICED sense2 board aleady.
And, Creating new item in Make Target of WICED Smart SDK was success and added wiced_sense in its pane as below.
But, In WICED Sense app of Adroid, TEMP, PRES, HUMD sensor worked very well, otherwise GYRD, ACCEL sensor didn't work.
So, l guess that method of Creating Make Target was wrong.
Let me know, how could i creating wiced sense.
I have one more qusetion.
My application product is insulin pump for diabetes.
There is external host, and i should developing interface between host to BLE.
So, i will use SPI interface of BCM(CYW)20736S module.
My board's pins were assgined as P02_CS_P24_CLK_P04_MOSI_P25_MISO.
In "spiffydriver.h" under "include/Drivers/20737" folder of SDK, above combination is not present.
Why isn't 20736 driver?
Could i insert above combination in "spiffydriver.h" source?
Please help me.
In addition,
From what i understand, i could try both using WICKED smart designer and spi-comm_slave-BCM920736TAG_Q32 download for spi.
When a code is generated automatically by selecting spi of Device Peripherals and Interfaces menu in WICKED smart designer, how it work?
I couldn't find source related SPI in above code.
Could i use spi-comm_slave-BCM920736TAG_Q32 download for my project?
I am sorry to have bothered you.
Thanks a lot.
There is nothing wrong in the definition of your target but I noted something unusual in the "Build command". I thought it should be a backlash dividing the folders but you had a "W" sign instead. I used a version 1.08 Wiced Sense Android APP with a Sense 1 and found no issue with it. Perhaps do a recovery and give it a fresh download.
If you cannot find the above combination in spiffydriver.h file, it simply means that it is not supported. There is a table that spells out the supported combinations in the WICED_Smart_Hardware_Interfaces.pdf that you can use. The spi_comm_master app would also be a good reference. I will not use the Smart Designer.
Hi btta,
I resolved WICED Sense2 problem using wiced_sense_2_factory_Firmware.
Please help SPI problem.
Thank you.
