After calling bleprofile_Init(bleprofile_p_cfg) in create function, current consumption looks higher.
So I added bleprofile_InitPowersave() and bleprofile_StartPowersave() end of the function.
Then the power consumption becomes lower.
Is this correct usage?
dmiya
StartPowersave is generally called by the system itself, you should not need to call.
Please check that in your profile config the powersave timeout is a non-zero value.
-Kevin
dmiya
I'm interested in power saving also.  I don't recall seeing that function discussed in the documentation and the comments in the header file are somewhat cryptic and don't explain exactly what it is for.  I would be interested in following this thread to see the answer(s).
What is your current power consumption looking like?  I have found that the ble_tracex() function calls will consume a LARGE amount of power.  If you have any traces in your code you should put
#define BLE_TRACE_DISABLE
at the top of your .c files.  This will turn your trace calls into no-ops and save power.
In my App I am sampling an ADC quite frequently and do not want to ever enter HIDOFF (deep sleep).  But I don't want to disable low power mode completely as that would drive the BLE chip to run at around 6 to 8 mAmps continuously.  So I allow "light sleep" in between sampling periods and the chip is currently drawing about 2 to 2.5 mAmps including the ADC which is very low power also.
Eric
dmiya
-Kevin
Kevin, Thank you for your comment. I'll try this later.
