Off-the-Shelf Programming Socket for BCM20736S Module?
dasmc_2125571
5 likes given First like received First like given
Is there an off-the-shelf socket that is available from Broadcom or some other entity that can be designed into a board/fixture (in conjunction with a TAG3 board) for the purpose of creating a custom programmer for a small number of the BCM20736S modules?
Although we have testpoints on our PCB for programming it, there is a need for a small number (~50) of the chips to be programmed before PCB assembly.
David Smith
dasmc_2125571
Updated info concerning source for off-the-shelf socket at:
Source of Production Programmer For BCM20736S
MichaelF_56
I am not aware of one off the shelf for the BCM2073XS family.
Note that Avnet​ and a few other Distributors in Asia have worked with us to setup mass programming services, so you could try them as well.
dasmc_2125571
