Hi forrest.chien, mwf_mmfae and j.t,
Here comes new problem. By referring to the below link:
How to do OTA: Step by Step with PDF
We test again for the OTA function of SDK2.2.2 under Windows 10.
The peerapp was successfully compiled, and we did paired with the target board, but it shows no device paired error all the time. In Win10 the bluetooth device management page seems changed. Please help.
It worked in Win7 before, but now we just have Win10, we can not find any old machine with Win7 now.
Hi all,
After I removed the WIDCOMM clearly in my Windows 10, the program works!
I just let the BT manager of windows works, pair with my device first. Then the program can show the BT address again.
But the WsOtaUpgrade of SDK 2.2.2 still not work.
Currently I just use the old one (WsOtaUpgrade of SDK 2.1.1) and let it proved my device can be OTA.
Please help to check the developer what the difference of WsOtaUpgrade between SDK2.1.1 and SDK2.2.2
Forrest, can you get in touch with this customer?
Hi boont,
He is working on it, I remove the WIDCOMM driver and tried to re-install it from the below link:
(Please download the link named "WIDCOMM® Bluetooth Windows® Software")
It always the below fail and I can not continue.
(The Chinese words means the script installation fail.)
Maybe I need to ask mwf_mmfae to have a try about this installation.
Hi all,
Henry,
Windows 10 uses its own BLE Stack - That's why you are getting your install error.
JT
Hi j.t,
Yes, thank you. I have passed this gap.
