Hi BCM supports,
I found another thread talked about the OOB feature:
Is encryption working between hello_client & hello_sensor?
The answered message mention that he use the old code for it, after checking the uploaded hello_sensor.c/hello_client.c from him. I found the files are identical with SDK 2.2.1. So what is the hello_sensor.c looks like? please kindly provide one, thanks.
Currently the OOB works well on my board now. The sample code are the same between these versions of SDK. I am now closing this issue. Thanks all.
For further more discussion, please help to check other thread which is still un-resolved.
Sorry, I mean what is the correct sample code looks like?
Hi j.t,
I tried and  installation fail, please refer to this thread:
How to really disable fine timer in BCM20737?
Hello Henry,
Try to add the patch below to your make file: disable_sw_timer_as_wake_source.a
That should work
JT
j.t,
Thanks, I have done the including, but it's not work.
