I am running into some error while making the target with WICED-Smart-SDK-2.1.1.
00:41:27 **** Build of configuration Release for project WICED-Smart-SDK ****
"C:\\Users\\amitag\\Documents\\WICED\\WICED-Smart-SDK-2.1.1\\WICED-Smart-SDK\\make.exe" WICED_SENSE-BCM920737TAG_Q32 download UART=COM66
make.exe[1]: *** No rule to make target '../../build/WICED_SENSE-BCM920737TAG_Q32-rom-ram-Wiced-release/drivers/l3gd20_driver.o', needed by '../../build/WICED_SENSE-BCM920737TAG_Q32-rom-ram-Wiced-release/A_20737A1-WICED_SENSE-rom-ram-spar.elf'.  Stop.
Makefile:329: recipe for target 'WICED_SENSE-BCM920737TAG_Q32' failed
make: *** [WICED_SENSE-BCM920737TAG_Q32] Error 2
How do I troubleshoot this error?
Amit
had the same issue.. check below.
In the video, it is mentioned that we take all the 19 files (including from the drivers folder)  and paste it in a new folder under WICED_SMART-SDK\APP\WICED_SENSE. You need to retain the driver\ subfolder while copying and the files within it as is..Don't copy just the files within as the makefile.mk is using the driver\<file_names>...
APP_SRC = wiced_sense.c drivers/l3gd20_driver.c drivers/hts221_driver.c drivers/lis3dsh_driver.c
APP_SRC += drivers/lps25h_driver.c drivers/lsm303d_driver.c
APP_SRC += ws_sec_upgrade_ota.c ws_upgrade.c rsa_pub.
I did the above and it worked with "WICED_SENSE-BCM920737TAG_Q32 download" as a Target Make.
Or you change the makefile and remove "drivers/".
Let me know if it worked..
hello amit,
Your Make file should look like this;
JT
Hi JT,
I checked the make file. It is same only.
Amit
Thank you so much. It worked ..
