Hi, mwf_mmfae
May I have some questions about BCM20737L or BCM20736S and regulatory certs? One of our customer is considering to use BCM20737L module and has some questions.
Q) Is FCC approval not required for BCM20737L since it had already done? And how about KC(Korea Certification) approval? In the "Broadcom BCM20732S BCM20736S BCM20737S Regulatory Approvals.pdf", there is no KC approval. If it’s needed, KC should be proceed by themselves. Right?
Sung-Mok
RegulatoryCertification
According to the Regulatory Team, the BCM2073XS SIP is not regulatory approved for Korea at the modular level (we tried and were unsuccessful). However, WICED Sense (attached) is approved at the system level.
I need to check with the team on regulatory for the "L" and determine if the existing certs can be leveraged for it as well. This product has not yet been released to the Mass Market, so it could be that the business unit is working on regulatory approvals now.
I verified today that our Regulatory team already has boards for the BCM20737L and will do regression testing to make sure everything is ok and add to the existing regulatory.
