I have a very crazy problem. Perhaps somebody had the same and could give me some hints.
My application is running fine on the TAG-Board. Now we created our own board.
Now my application stopps after some ms. The create()-function is done completeley. I added a counter to the finetimer. This shows the finetimer stopps after ~15 - 19 counts with a intervall of 12.5 ms.
I also tested with proximity with the same result. Running on the TAG-Board, but only starting on our design.
I check Vbat, Reset and WP-Pin, should be OK
Nothing else is connected at the moment on our Board.
Are you using an 2073xS module? If this is a chip on board design, what are main crystal cap values? Search the forum for xtal (or crystal) warmup and there are a number of discussions on this issue.
