- Email to a Friend
I understood that the application was using the space in VS1 for peering data and also for bleprofile_*NVRAM.
But what is the physical offset from VS1 those functions are using on the EEPROM ?
I would like to access directly the EEPROM via bleappfwu_*Mem and store some information in this VS1 area without messing with the application.
How much do I have left on the 1024 bytes area and at which offset ?
FlashEEPROM
- Email to a Friend
You should always use bleprofile_*NVRAM functions add/modify/delete items to the VS. If you use bleappfwu_*Mem functions with addresses in the VS area, there is a very good chance that you will lose pairing information at best or brick the device at worst.
- Email to a Friend
This posting has more information on your application using this memory area: Re: Programming manufacturing data during production.
- Email to a Friend
There is also this one: Re: nvram: number of locations to write to
- Email to a Friend
