SDK: 2.2
Tag: 920737.
app: hello-sensor.
firmware size ~ 28KB.
Description:
Current hello-sensor support 1 handset to connect without any security mechanism.
We find once if someone who have no permission to access the link coincidently connect with the device,
can slave-side call any function to dis-connect the link and reset its MAC address so as that ROOT can
get the right to access the link? Besides, if calling this dis-connection function, is it dangerous that
to break the state machine in L2 STACK level so that handset cannot activate the new connection again? TKS.
Could you check this function 'blecm_disconnect'? I use it to disconnect the connection to either master or slave role.
But I don't know how to reset the MAC address. Is it possible? referring to How to change MAC address randomly while running
