Is the connection idle timeout settable in runtime?
The connection timeout is set at power up in the create function:
1. Our definition:
#define CONN_TIMEOUT     5          // In seconds
2. In  config array const BLE_PROFILE_CFG my_app_cfg:
/*.con_idle_timeout               =*/      CONN_TIMEOUT,   // In seconds
My question is:
Is there an API to change it later, when the code is already running?  If so, what is the call that I have to use to set it to the new value?
Thanks!
Cheers,
Gil
This is how you do it:
Maximum is 255 seconds:
UINT8 timeout;                    // Set it to any value <= 255
Example:
timeout = 10;
Code:
bleprofile_StopConnIdleTimer();
bleprofile_StartConnIdleTimer(timeout, bleprofile_appTimerCb);
The "stop" call is needed if the timer has been previously started.
Cheers,
Gil
MichaelF_56
I've asked jamesle1​ on the applications team to take a look at this and respond.
Hi mwf_mmfae,
Any news from him?
Gil
No.  I am out of the office till next week, so I need to check his schedule.
Example:
timeout = 10;
Code:
Cheers,
Gil
Thanks Gil.
jamesle1
