Is it possible to write values into specific area only through chipload?
Is there any way to write data into specific area (for example 0xF8008000 ~ 0xF8009000) without changing the other area through chipload.exe in BCM920736 of Wiced2.1.1?
Currently chipload.exe writes the entire area from 0xFF000000 (or F8000000).
Thank you.
BoonT_56
Check out the "Configure Section Layout" of the below:
WICED Smart BCM92073X EEPROM and SFLASH Layout
BoonT_56
