Is it possible to disable the ble stack and all ble functionality from within the application and enable it again after performing an servicing an interrupt. The reason for this is I have an interrupt that's missing pulses due to what I assume is the ble stack. I checked this by not using any of the ble functionality and simply having my application consist of an interrupt that counted pulses. I was able to count 60 pulses at 5Khz, something I just wasn't to archive with the ble active.
Thank you in advance
MichaelF_56
I'm fairly certain that this is not possible on the BCM2073XS Devices.
is there anything I can do to archive so emulate disabling it? can I give my interrupt higher priority? is it possible to get access to the interrupt register directly and count get the number of times a pulse triggers the interrupt?
I was able to get my interrupt to run reliably by not running the fine timer, putting a zero in the cfg for the fine timer seems to have stopped issues I was having and I was able to get my interrupt to count over 200 pulses at frequencies upwards of 2kHz
