Smart Bluetooth
Hi All,
We are using WICESDK for BCM20376, need to implement OS functionalities. Just wanted to clarify if the WICEDSDK supports OS concepts like creating thread,signals/events etc ? If so is there any documents bearing these?
Prasanna
MichaelF_56
The BCM2073XS family runs ThreadX under the hood.
The application itself is not able to access any of the API functionality as much of this functionality is abstracted to the simpler, much higher level APIs that the SDK provides.
For instance, the application is not allowed to do do things like create/destroy threads ad the application runs in its own thread.
MichaelF_56
Thank you for your quick response.It answered my question.
