Internal & External Reset
WaSu_1697556
BCM20736(SoC) datasheet mentions Internal & External Reset.
Are both Resets exactly the same from the point of target application running?
BoonT_56
To reset the 20736, we use an external active low signal RESET_N to do it. So you should concern yourself with the ext reset.
