Aug 20, 2015
02:41 AM
Aug 20, 2015
02:41 AM
BCM20736(SoC) datasheet mentions Internal & External Reset.
Are both Resets exactly the same from the point of target application running?
12:36 AM
Aug 21, 2015
12:36 AM
To reset the 20736, we use an external active low signal RESET_N to do it. So you should concern yourself with the ext reset.
12:36 AM
Aug 21, 2015
12:36 AM
Aug 21, 2015
01:42 AM
Aug 21, 2015
01:42 AM
OK thanks, after reading your comment I re-read the datasheet and now it makes perfect sense.
