The BCM20732 supports the use of Serial Wire Debug (SWD) debug/trace messages that are output through the HCI UART port that's onboard. The SWD pins are muxed with HCI UART and are used in such a manner that the hardware and firmware can auto-detect the presence of SWD or the HCI host; this means that HCI based download and debugging are mutually exclusive of one another.
In order to use these debug/trace output facilities from the HCI UART, you would need to:
1.) Closest to the BCM20732S (note that the JP1 header resides on the other side of the FTDI USB to USB converter, so it will not work), create a set of jumpers to an external header that contains the following signals: SWCLK = HCI UART_TX, SWIO = HCI UART_RX (the SWD SWO signal is not supported)
2.) Set ble_trace_enable = 0 when initializing the application
3.) Once debugging is complete over SWD, return ble_trace_enable to its default state to enable downloads
Note: Setting ble_trace_enable = 2 will output printf style traces to the HCI uart, which will then interfere with the symbolic debugger over SWD.
Unfortunately there is not an appnote available which shows how to setup a proper debugging environment within the existing SDK.
It looks like you learned about our upcoming J-Link capabilities within this thread: Re: How to debug the board step by step?
So were hoping that this will improve the debugging environment available within the WICED SMART SDK.
