I would like to temporarily disable the watchdog or increase the timer.
Is there a way to do it ?
Thank you.
Use this (with caution):
extern void wdog_configure(UINT8 enable);
wdog_configure(FALSE) - this will disable the watchdog.
wdog_configure(TRUE) - this re/enable the watchdog with the default settings.
There is a similar issue discussed here where the SW team showed the user how to restart the watchdog manually: Re: Wiced Smart Software Runtime -- Lots of Questions
I know that we can kick the watchdog but I want to disable it or increase the timeout.
Thanks a lot, it works !
