In BCM20737S, I want to use Real time clock function.
Let me know the method of the initialization using outside CLK.
Thank you for your help.
BoonT_56
I would like to refer you to the rtc_sample app in the SDK. At the beginning of the source code, there are some description on how to use this app (with the tag3) in conjunction with an external 32 KHz LPO (enabled by default on tag3 by the way).
BoonT_56
Thank you for advice.
I was able to solve the problem.
