I see the following while trying to build the hello_sensor on MAC using the 2.1.1 IDE.
**** Build of configuration Release for project WICED-Smart-SDK ****
"/Users/user/Documents/Electronics Software/WICED Broadcom/WICED-Smart-SDK/make" hello_sensor-BCM920736TAG_Q32 download
Unknown host
Linux32 uname: ""
Linux64 uname: ""
OSX uname: ""
Win32 uname: ""
Build Finished (took 223ms)
VikramR_26
10 sign-ins 10 comments on KBA 5 comments on KBA
There is an issue with the sdk and would be fixed in next release, related to perl version on new Mac OSX .As a quick workaround,
1)Rename Tools/common/OSX/perl to perl.old
2)Create a symbolic link from from Tools/common/OSX/perl to the system's perl
ln -s /usr/bin/perl Tools/common/OSX/perl
and you can try hello_sensor to verify it works
thnx
vik86
VikramR_26
Hi Sambhav,
I tried reproducing and was not successful, could you kindly make sure the installation was successful, also I'm guessing in your installation path "Electronics Software/WICED Broadcom/" there are spaces and this might be causing it. Could you kindly re install and avoid spaces in your folder names, check these and let us know if you still see the issue.
thnx,
vik86
I changed the folder and the installation was successful. But while building the helo_sensor this is the error
make[2]: *** No rule to make target `base'.  Stop.
make[1]: *** [../tier2/brcm/mandatory/bld//patch.symdefs] Error 2
make[1]: *** Waiting for unfinished jobs....
make: *** [hello_sensor-BCM920736TAG_Q32] Error 2
VikramR_26
Could you paste the complete error . Also could you tell me your mac os version.
vik86
My mac version is 10.10.
The console prints this:
03:12:20 **** Build of configuration Release for project WICED-Smart-SDK ****
/Users/feetlost/Documents/WICED/WICED-Smart-SDK-2.1.1/WICED-Smart-SDK/make ibeacon_device-BCM920736TAG_Q32 download
dyld: Library not loaded: /System/Library/Perl/5.12/darwin-thread-multi-2level/CORE/libperl.dylib
  Referenced from: /Users/feetlost/Documents/WICED/WICED-Smart-SDK-2.1.1/WICED-Smart-SDK/Wiced-Smart/spar/../../Tools/common/OSX/perl
  Reason: image not found
make[1]: *** No rule to make target `../tier2/brcm/libraries/lib//additional_advertisement_control.a', needed by `../../build/ibeacon_device-BCM920736TAG_Q32-rom-ram-Wiced-release/lib_installer.c'.  Stop.
make: *** [ibeacon_device-BCM920736TAG_Q32] Error 2
03:12:21 Build Finished (took 453ms)
In the problems window I see this
DescriptionResourcePathLocationType
make[1]: *** No rule to make target `../tier2/brcm/libraries/lib//additional_advertisement_control.a', needed by `../../build/ibeacon_device-BCM920736TAG_Q32-rom-ram-Wiced-release/lib_installer.c'.  Stop.WICED-Smart-SDKC/C++ Problem
make[1]: *** Waiting for unfinished jobs....WICED-Smart-SDKC/C++ Problem
make[2]: *** No rule to make target `base'.  Stop.WICED-Smart-SDKC/C++ Problem
make[1]: *** [../tier2/brcm/mandatory/bld//patch.symdefs] Error 2WICED-Smart-SDKC/C++ Problem
make: *** [ibeacon_device-BCM920736TAG_Q32] Error 2WICED-Smart-SDKC/C++ Problem
Hope this helps. Let me know if you need anything else!
Please try building hello_sensor-BCM920736TAG_Q32 first.
ibeacon_device-BCM920736TAG_Q32 requires a library that will be provided only to MFi licensee.
Please read README.txt carefully.
VikramR_26
thnx
vik86
I had the same issue.  Thanks vik86 for the instructions . . .fixed!
This worked! Thanks!
This also worked for me! I am running OSX 10.11.1 and using the WICED Smart SDK 2.2.0. Thanks vik86!
