Hi all,
After I changed wic file once, I'm not be able to watch any services and characteristic on LightBlue app.
In WICED Smart Designer Software User Manual, there is a NOTE: This file (about .wic file) should not be edited.
Does that mean I cannnot use the project if I change .wic file?
Although, I cycled power of iPhone, this problem was not resolved.
Please tell me what to do.
No, I don't recommend editing .wic file.
You can edit .c source code and/or .h header file directly if you want.
Do you often use Designer during development?
Usually, it's used once at the beginning of development I think.
.wic file is used only by Designer.
So if you change .wic file after generated code by Designer, it's no problem.
And I recommend to use version control system like Git/SVN.
Then you can recover workable .wic file from it.
Hi dmiya
No. However, I must sometimes respond to deviation.
Of course, I use Git. So, I applied previous code .wic file, but I could no longer use the project.
In short, cannot I edit .wic file under development?
