I just installed Modus Toolbox 2.0.
I wanted to choose wiced_btsdk for Board: CYW920819EVB-02. I get the error message: Failed to locate modus-shell.
I am running Linux.
What can I do?
ispn:38628:1:0
l1:314:1:0
Hello DheerajP_41,
I forgot to let the post installation scripts for Linux run. Now it works. Thank You.
M. Schulze
Please check whether you have done all the steps mentioned in the document https://www.cypress.com/file/492936/download .
Also, Could you please share the error log with us? (copy the modustoolbox console logs).
Please note: You don't need to import wiced_btsdk for each and every platform. wiced_btsdk contains the SDK (platform files, libraries,...), which is used by all BTSDK applications. You will need to create this project just once in the working directory (i.e., Eclipse workspace). Ignore if you already created this project earlier. Please see the attached user guide.
-Dheeraj
Hello DheerajP_41,
M. Schulze
Good to know that it worked for you.
ModusToolbox Installation Guide : https://www.cypress.com/file/492936/download
